oil pressure gauge
Old Sep 12, 2007 | 03:49 PM
barstickbilly's Avatar
barstickbilly
Default oil pressure gauge
98 dakota 3.9 magnum was droping oil pressure, pulled pump,screen was pluged,cleaned it replaced pump but still when it idleing below 1000 rpm oil pressure drops to 0, give it gas and it goes up,????
Old Sep 12, 2007 | 05:12 PM
Chris's Avatar
Chris
Default RE: oil pressure gauge
It could be something as simple as your overall oil level. When you rev your motor up, what psi are you seeing? It also could be a faulty gauge. Try using a mechanical gauge to make sure the readings are correct.
Old Sep 12, 2007 | 07:37 PM
SrtHemi's Avatar
SrtHemi
Yea check the gauge, If the reading is correct then as long as you have oil pressure you are ok, I had a 78 Ford one time that had 60 psi but once she got hot she dropped all pressure and began the thrashing--(which was a spun rod bearing).
Old Sep 12, 2007 | 07:39 PM
varsis's Avatar
varsis
Mine did this for a bit. Than it went away? Im not sure what it was but as long as the engine is running it is probably fine.... Just something with the wires or such.
Old Sep 13, 2007 | 08:21 AM
yellowjacket99's Avatar
yellowjacket99
Make sure your oil level is correct, then definetly get a mechanical gauge to check it. If you search on here you'll see Dakota's tend to have low oil pressure when idle, but it shouldn't be 0. You're best bet would've been to buy a new pump and pick up tube and put those in.
