ECM question
Old Sep 12, 2007 | 09:14 PM
tidd1340's Avatar
tidd1340
Default ECM question
Is it a common thing for these to go bad? Im at my wits end figuring out my cold engine stumble..new O2 sensors,cam pos. sensor,plugs,wires,rotor,cap,and a new coolant temp sensor.When warm it runs fine.Has to hit full operating temp,or truck wont pull over 2000 rpm's.Got a random misfire code,but it cleared itself.I used a scanner to watch the misfire count..they go up to 10-15-20 or more..some cylinders more than others(i did get a random misfire code).But then the scanner goes to all zeros,like the ECM resets itself.Then it starts all over.Is that normal? Is there a place on the net i could get the numbers i need to run the scanner and compare live data to what im getting? Its a 3.9 w/o air..manual tranny.
Old Sep 13, 2007 | 10:02 AM
superdak05's Avatar
superdak05
Default RE: ECM question
go to www.allpar.com and they have a list of codes for the truck
Old Sep 13, 2007 | 10:47 AM
Chris's Avatar
Chris
Sounds like a compression problem. Have you checked the compression on the cylandars?
