dyno test
Old Sep 22, 2007 | 02:51 PM
98whitekota's Avatar
98whitekota
Default dyno test
hey dose anyone know of a shop in sothern cali that dose dyno tuning for dodge cars and trucks? i remebemr one but i forgot the name of it and i cant find it.
Old Sep 22, 2007 | 04:21 PM
rtkota5point9's Avatar
rtkota5point9
Default RE: dyno test
Are you running forced injection? What are you using to change fuel and timing?
Old Sep 23, 2007 | 01:10 PM
98whitekota
na its n/a but bigger cam and i just want to get timing advanced a bit, and get some dyno numbers
Old Sep 23, 2007 | 06:47 PM
rtkota5point9
Well you need something that will allow you to change the timing. If you just bring your truck to a dyno shop as is, they can't do anything about it. You can't advance the timing by just moving the distributor like older vehicles. Everything's controlled by the computer. You either need to send the PCM out to a company like B&G to get flashed for what you want (advanced timing), or buy a piggyback like a MSD-6AL with BTM add-on, or get a module like the new SCT tune, and then go to a dyno that has the programmer for it and they can change any paramiters that you want.
