ABS PUMP RUNS CONTINUESLY
Old Oct 2, 2007 | 07:23 PM
carl h's Avatar
carl h
Default ABS PUMP RUNS CONTINUESLY
I put my brakes on the other day comming to a stop sign and the ABS pump activated and would not turn offnow the ABS and the Brake Light lights are on on the dash. To get the pump to stop after shutting off the truck I had to unplug the pump. Also the truck has a stalling issue when I come to a stop, And the speedometer does not work. Any Ideas? I've been reading about the rear differential speed sensor but haven't read anything about the pump activateing or the stalling issue with other peoples posts. Any help would be greatly appreciated.
Old Oct 3, 2007 | 09:38 AM
f0x672's Avatar
f0x672
Default RE: ABS PUMP RUNS CONTINUESLY
most likely your speed sensor went... about the stalling do any recent tune ups? and give your vacuum lines a good inspection
Old Oct 3, 2007 | 12:58 PM
Nicegy525's Avatar
Nicegy525
have the abs codes scanned to determine where the fault is.
Speedo is most likley the speedo cable. Does your odometer turn over?
Stalling could be tune up related.are there anycheck engine codes?
Old Oct 3, 2007 | 10:14 PM
carl h's Avatar
carl h
Hi, All these problems happened at the same time. First the pump would'nt stop running, I unplugged it to stop it. Second the speedo would'nt work. And third it started stalling when I pushed the clutch in. All this in a matter of 5 minutes. The stalling isn't a vacum leak issue or a tune up issue. Has to be related with ABS thru the electronics. I just need to figure out what art to check before I just start replaceing parts.
