electric radiator fans
Old Oct 9, 2007 | 09:40 PM
ram1000's Avatar
ram1000
Default electric radiator fans
Anyone install these and increase gas mileage?
Old Oct 9, 2007 | 10:03 PM
User's Avatar
User
Default RE: electric radiator fans
If you take out the clutch fan yes it will take lagg off the motor and increase mpg, i removed my clutch and used stock e fan and noticed a gain.. avg avout 15miles a tank.. depends on my foot.. the most ive ever gotten was 20.. thats over a full tank.
Old Oct 10, 2007 | 02:46 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Ihave added someEletric fans. It will Improve your performance. Just you will have to cut off the fan cluch. realy easy. I use 5 eletric fans in my truck. You would be okay with 2 large ones. I live where it gets over 110 and I tow and I like to have the ac on while towing while keeping my engine and tranny and engine oil cool. Check out https://dodgeforum.com/m_993170/tm.htmandhttps://dodgeforum.com/m_945919/tm.htmfor more info. and Check out https://dodgeforum.com/m_996055/tm.htm
[IMG]local://upfiles/70180/FFA14BCEC29D428AAAB8345C8C62E879.jpg[/IMG]
[IMG]local://upfiles/70180/05D57F27DCE34BA7800FBBD590848F0C.jpg[/IMG]
[IMG]local://upfiles/70180/15D5B4F6C5C646A1B1418ED6D476D183.jpg[/IMG]
Old Oct 10, 2007 | 09:12 AM
ram1000's Avatar
ram1000
I see some guys have used fans from other vehicles but there are a number of after market suppliers for these fans. I presume that thse after market fans would be equally efficient???
Old Oct 11, 2007 | 11:13 AM
lone_wolfin's Avatar
lone_wolfin
there are aftermarket manufacturers for the electric fans, but are WAY TO EXPENSIVE (over a couple hundred $$ for a good brand name).....
The Lincoln Mark 4 or 5(i believe) is a good one, but could draw alot of amperage i would presume....
I went with the Mustang 5.0 cooling fan......i turned it 90* and mounted itso the fan is towards the top (where most of the cooling is needed on my stock 02 Dakota radiator).....
the fan was inexpensive ($30) from a bone yard and replacement motors can be bought anywhere for a small cost as well....alot easier than aftermarket fans once it is set up....
