power window
Old Oct 16, 2007 | 10:20 AM
kjun's Avatar
kjun
Default power window
Does anyone know if the power window motor/regulator is the same for both the front and rear drivers side windowson the quad cab?
I have a 2002 QC and the drivers side power window regulator is toast. If they are interchangeable I can put off getting a new one for while.
Old Oct 16, 2007 | 11:00 AM
jnwolf2000's Avatar
jnwolf2000
Default RE: power window
Per Autozones parts look up they are different parts numbers. Sounds like the front and rear will not interchange.
james
Old Oct 16, 2007 | 11:56 AM
kjun's Avatar
kjun
Thanks. Afraid of that.
Old Oct 16, 2007 | 01:49 PM
varsis's Avatar
varsis
ORIGINAL: kjun
Does anyone know if the power window motor/regulator is the same for both the front and rear drivers side windows on the quad cab?
Probably can swap the driver and Passenger motor This might be a good idea. lol No air for your passenger though.
Old Oct 16, 2007 | 04:07 PM
kjun's Avatar
kjun
I'll look at it but it mightbe the same issue as the front and rear. I believe there are 2 different P/N's as well. The actual motor is fine. Its the regulator that is messed up. I've tried replacing the cables but just can seem to get it right.
