leak detection pump...p1494 help?!
Old Oct 21, 2007 | 08:34 AM
eclancy's Avatar
eclancy
Default leak detection pump...p1494 help?!
what in the name of god is a leak detection pump, and where do i find it? truck is throwing code p1494 "Leak Detection Pump Switch or Mechanical Fault". i need to get an inspection, and this just happens to happen. i can shut it off for two days with my scantool, but then it comes back on.
Old Oct 21, 2007 | 09:31 AM
imnothot02's Avatar
imnothot02
Default RE: leak detection pump...p1494 help?!
under the fuse block
Old Oct 21, 2007 | 09:38 AM
f0x672's Avatar
f0x672
its behind the left headlamp infront of the power distribution center, it has 2 wires going into the top of it, you'll see it
Old Oct 21, 2007 | 09:40 AM
imnothot02's Avatar
imnothot02
^ ur rite
