DIY threads...
Old Oct 23, 2007 | 09:41 AM
steve05ram360's Avatar
steve05ram360
Default DIY threads...
I've started a thread at the top for quick links to the DIY writeups that have been done on the 2nd gen Dak... If you can give me a link to your's or ones you've seen/used here I'd appreciate it. it'll make it alot easier to find info when you need it.
Have a look at the 2nd gen ram thread https://dodgeforum.com/m_904616/tm.htmand look at the format of the DIY writeups. Pictures mixed with text... helps alot.
thanks
Old Oct 23, 2007 | 11:13 AM
varsis's Avatar
varsis
Default RE: DIY threads...
I could write up DIY but I wouldn't have any pics...
Old Oct 23, 2007 | 12:07 PM
steve05ram360
on what? I'm mostly looking for ones that have already been written in a thread and any new ones that come up. they would tend to be the most accurate as they are usually done soon after the work. If you do any work to your truck and plan on doinga DIY on it, take pics of the work as you go. if you need help putting one together, I can help with that and guide you in the right direction.
Old Oct 23, 2007 | 01:39 PM
varsis's Avatar
varsis
Well I could write up stuff like removing the transmission, valve covers, hub replacment, timing chain, but they are all already out there.
