engine knocking
Old Oct 31, 2007 | 11:18 AM
jreschar's Avatar
jreschar
Default engine knocking
Moved to Texas from Colorado and now my engine knocks especially with the A/C on which is most of th time here in the summer. I ran in colorado on lowest octane. Suggestions helpful.
Old Oct 31, 2007 | 11:29 AM
varsis's Avatar
varsis
Default RE: engine knocking
Difference in elevation, Try Resetting the computer.
Old Oct 31, 2007 | 11:34 AM
Chris's Avatar
Chris
ORIGINAL: varsis
Good thinking.
Old Oct 31, 2007 | 03:17 PM
Mean Green's Avatar
Mean Green
Also if that doesn't work for you try a higher octane. At a lower elevation you get more air into the engine which makes higher compression and if you were on the verge of knocking up in CO it would be easy to see why you are knocking down in TX
