Horn, Dome Light, & Radio Not Working
So I blew a fuse when connecting a new battery. Replaced it, checked all the others, but now my 2000 Dodge Dakota still won't let the radio, dome light or horn work. Every fuse has been checked and rechecked. Any ideas on where to look for this problem? A wiring diagram maybe?
look in the fuse box on the driver side of the dash...there should be a fuse that has black plastic around it that has tabs..you prob wont even be able to see the fuse...pull it and check it...should be at the upper left
I got the horn working. It was a blown fuse. though the radio and dome light still do not work. I checked and they are not getting power sent to them. the radio hasa pink powerline that does work, but a blue one that does not. The blue one I believe is the main power as it has an inline fuse. But the power isn't even reaching the fuse.
