stalls in reverse in colder weather
Old Nov 5, 2007 | 06:51 PM
ccap's Avatar
ccap
Default stalls in reverse in colder weather
My 2002 Dakota stalls in reverse only in colder temperatures (under 50 degrees or so).Starts fine, run it a mile or so put it in reverse and it stalls.I've changed the Throttle Position Sensor and the Idle Control Valve and no change.Can you help???????????
Old Nov 5, 2007 | 08:23 PM
varsis's Avatar
varsis
Default RE: stalls in reverse in colder weather
Check your oil levels. Tranny, engine, coolant. Maybe time for a tranny flush/change of filter so on.
Old Nov 5, 2007 | 08:39 PM
ccap's Avatar
ccap
can a low tranny fluid level actually cause the truck to stall?I was going to change the crankshaft position sensornext (which was another suggestion I've heard).Is this a possibility?
Old Nov 6, 2007 | 01:10 AM
varsis's Avatar
varsis
Could, but probably wouldn't if it's in park (The fluid doesn't move.) Why in cold versus warm i don't know.
