O2 Sensor Codes
Old Nov 10, 2007 | 12:02 PM
01dakv686's Avatar
01dakv686
Default O2 Sensor Codes
P0132 and P0138
P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
P0138 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range
what is 1/1 and 1/2? driver side up and downstream?
Old Nov 10, 2007 | 10:53 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: O2 Sensor Codes
Yes. Bank1, sensor 1 and bank 1, sensor 2. Check you wires to makes sure they didn't rub through and cross the heater 12v power with the signal. Wires OK, replace the sensors.
