injectors?
Old Nov 12, 2007 | 02:03 PM
mikedasniper2000's Avatar
mikedasniper2000
Default injectors?
hey ive got a 5.2L running a holley 52mm TB, and a mopar intake manifold.. what size injectors would be best to use?
Old Nov 12, 2007 | 09:16 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Default RE: injectors?
Stick with stock size unless fuel trims are constantly positive. No sense in spending more money if it's not gonna help anything.
Old Nov 13, 2007 | 12:09 PM
SinCity R/T's Avatar
SinCity R/T
The OEM injectors are sufficient to handle all of the standard bolt-ons for the 5.2L/5.9L V8's... Even a lot of the heavy mod R/T guys are still running the OEM injectors. Without some sort of aftermarket tuning option (ie: standalone controller, SCT tune, etc.) you will typically run heavily rich at idle if you swap injectors.
Old Nov 13, 2007 | 05:36 PM
Chris's Avatar
Chris
Get an adjustable feuel pressure regulator if you choose to run aftermarket injectors.
