valve springs?
Old Nov 13, 2007 | 12:31 PM
mikedasniper2000's Avatar
mikedasniper2000
Default valve springs?
hey, im running a comp cam with 216/224 @ .506 Gross Valve Lift i was just wondering what springs and rockers would be bestfor my 5.2L. Also if any one knows of a good stud conversion kits im thinking about upgrading the studs and using chevy rockers.. any opinions?
Old Nov 13, 2007 | 05:33 PM
Chris's Avatar
Chris
Default RE: valve springs?
A lot of people have had success with the stock 1.6 rollers, as the 1.7's can be overkill with your cam.
Chris's Avatar
Chris
Also, as far as springs, check out www.socaldakota.com
Old Nov 13, 2007 | 10:49 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
First of all, Comp isn't the best brand for Mopar's. They tend to grind everything as though it were for SB chevy. Iskedarian, Lunati or MoparPerformanceare best.
Second, .506 at the valves with stock 1.6's ain't enough to warrant different valve springs.
Lastly, what do you see as the benefit of going with GM rockers? I mean, I can't even see that the offset or height would allow the interchange, but assuming it would.........................
