Dashboard "brake" light on....
Hey guys,
I just replaced the RWSS because my ABS light was on and so was the BRAKE light on the dash. After replacing, the ABS light went off but the BRAKE light is still on. Do I have to clear some code or something? Can I disconnect the battery for a few minutes to clear the code? Thanks!!!
Try disconnecting the battery Also check your Brake fluid level. But Usally both lights turn on? Check make sure it's not in Park too. Sometimes they like to stick with a click or two.
