Corner lights? Bulb but no lighting?
Old Nov 22, 2007 | 10:40 PM
w9awx's Avatar
w9awx
Default Corner lights? Bulb but no lighting?
For some reason, my corner turn signal bulbs don't seem to work. Are they not supposed to go on with my turn signals?
[IMG]local://upfiles/76446/F0C56F97D4DF49A6A0976DF6DDB513CA.jpg[/IMG]
Old Nov 22, 2007 | 10:53 PM
SinCity R/T's Avatar
SinCity R/T
Default RE: Corner lights? Bulb but no lighting?
There is three bulbs per corner lens - 2x 3157's which are the turn signals, and 1x 194 bulb which is the parking light.
It is correct that the outermost 194 bulb does not illuminate with the 3157's when you activate your turn signals.
Old Nov 22, 2007 | 11:01 PM
w9awx's Avatar
w9awx
So are those bulbs suppose to light up with the marker lights because I can't get them to light either with the running lights or with the turn signals.
Old Nov 22, 2007 | 11:28 PM
SinCity R/T
Here's a MS Paint Doodle that should describe it better...
The 194's should light up when your headlights are turned on. They will not illuminate with the 3157's when the turn signals are on.
Old Nov 23, 2007 | 09:42 AM
w9awx's Avatar
w9awx
Ok, I'll have to test the bulbs and the sockets to see why the are not working.
