rocker arm adjustment
Old Nov 23, 2007 | 05:32 AM
98whitekota's Avatar
98whitekota
Default rocker arm adjustment
any one know how to adjust rocker arms? i know that u have to tighten the rocker arm bolt down until there is no slack in the pushrod. then tighten the rocker arm bolt another 1/4 of a turn. the part i dont know is the pattern u have to do it in, like its TDC then u do 4, then you turn the engin over 180 degrees and do the other 4. dose any one know the pattern or sequnce that u have to do it in? please HELP!!
Old Nov 23, 2007 | 09:28 AM
varsis's Avatar
varsis
Default RE: rocker arm adjustment
In the manual it just says rotate to TDC. Allow 5 minutes for lifters to bleed. And tighten bolts to 21 ft pounds. This is on the 5.9l engine. Im sure it's the same for all the others.
Old Nov 23, 2007 | 08:23 PM
mikec04's Avatar
mikec04
Manual (Haynes) says to line up V8 or V6 mark on damper to the TDC mark on block. This is the neutral point in the engine's directional rotation and the point where the rockers can be tightened.
Best to get a repair manuaql if you are going to do any work that you are not sure of.
Edited due to speeeeling and being otherwise scatterbrained.
Old Nov 25, 2007 | 06:45 PM
Durango911's Avatar
Durango911
If you want to do it properly, follow these instructions:
[IMG]local://upfiles/64509/8C429E62F367412995374FA1AAA45F07.jpg[/IMG]
