Rear End Noise
Old Nov 25, 2007 | 11:24 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default Rear End Noise
I have an '00 dak with a 4.7 in it. My problem is when i turn i hear a weird clank in the rear end. it only happens when i turn. it is driving fine and it doesn't seem to be affecting the way it drives. i have not had the chance to get underneath the truck yet i was just wondering if anyone had a clue where i should start?
thanks in advance
Matt
Old Nov 25, 2007 | 11:36 PM
durangeddurango's Avatar
durangeddurango
Default RE: Rear End Noise
I would start at the obvious first exhaust hangers,lugnuts,if those are good then check rear brakes(drum or disc?) from there i would go inside the diff. if your positive the noise is in the rear.
