Power Steering Problem
Old Dec 4, 2007 | 12:33 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default Power Steering Problem
I have a 2000 dak with the 4.7 2wd. I am having a problem with excesive whine from the power steering pump when the truck gets warmed up. my question is that is there any other reason that is cheaper and easier to fix this problem or is it simply that it is going bad and the whole pump needs replaced?
thanks in advance
Matt
Old Dec 4, 2007 | 03:59 PM
Chris's Avatar
Chris
Default RE: Power Steering Problem
That sounds like a pump going bad personally. Is the fluid level correct? Have you ever let the fluid level fall below recemmended tolerances?
Old Dec 4, 2007 | 04:08 PM
MTN13's Avatar
MTN13
I topped it offa while ago but it was still in the tolerance level. I have been watching it and im not loosing fluid.
Old Dec 6, 2007 | 01:21 PM
chris1974's Avatar
chris1974
I have a 2003 4.7, 2WD. Mine does the same thing. Has never been low, and never lost a drop. I just ignore it.....and turn up the music- then the sound of the pump goes away! lol.
Old Dec 6, 2007 | 03:03 PM
MTN13's Avatar
MTN13
That is exactly what i have been doing and what i am going to continue to do until it either goes out or just stops!
Old Dec 6, 2007 | 03:25 PM
steve05ram360's Avatar
steve05ram360
have you flushed the power steering system at all? I suggest it if you havent. like any other fluid, it gets dirty and should be swapped out.
Old Dec 6, 2007 | 04:09 PM
chris1974's Avatar
chris1974
ORIGINAL: steve05ram360
I have. Can fluid that's just a little dirty cause a noisy pump??? I could see it if it was super dirty and had foreign debris floating around in it.
