schrader valve on fuel rail
Old Dec 14, 2007 | 09:24 PM
wink2873's Avatar
wink2873
Default schrader valve on fuel rail
Hey guys. When I changed my intake manifold I think I may have damaged the schrader valve on the fuel rail. It is leaking out fuel, sometimes pretty bad, sometimes just barely. At first I thought it was just because I lost the cap, but I got another cap and it still leaks out. How do I go about changing the schrader? What type of tool will I need and where do I find one? what size is it..etc???
thanks guys
Old Dec 14, 2007 | 11:33 PM
00DakR/T's Avatar
00DakR/T
Default RE: schrader valve on fuel rail
Go to your local auto parts store and see if you can find a tire valve stem remover tool. Its usually with the fix-a-flat and whatnot. This tool should remove the schrader valve from the fuel rail and you can replace it with one for a tire valve stem.
Old Dec 15, 2007 | 12:28 AM
wink2873's Avatar
wink2873
ok thanks
Old Dec 15, 2007 | 11:09 AM
steve05ram360's Avatar
steve05ram360
make sure you relieve the pressure in the rail before yanking the valve out... yank the fuel pump relay and fire it up.
Old Dec 15, 2007 | 03:40 PM
wink2873's Avatar
wink2873
there is no pressure because it leaks out everywhere... hence the problem
