CEL Code 0400
Old Dec 26, 2007 | 02:24 PM
mmaloney8's Avatar
mmaloney8
Default CEL Code 0400
Engine light came on yesterday, with a code of P0400. Looked thru list of codes on this site, but it is not listed. Can anyone tell me what it is?
Also notice truck started to run a little rough. thinking it might be cracked vacumn line.
Have an 03 Quad Cab 4.7L
thanks for your help.
Old Dec 26, 2007 | 03:19 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default RE: CEL Code 0400
in my chiltons manual it says that the p0400 is an Exhaust gas recirculation flow malfunction. I looked up the code and it says it is a problem with the egr valve, or a blockage in the linewich is vacuum operated so it could be a cracked vacuum line, or the egr valve. Hope that helps!
Old Dec 26, 2007 | 05:15 PM
mmaloney8's Avatar
mmaloney8
Thank you for the info. tonight after work I'll check the vacumn lines , then go from there. I appreciate the help.
Old Dec 26, 2007 | 10:27 PM
wink2873's Avatar
wink2873
well you dont have an EGR so that narrows it down a little.
