replaced battery
First cold day and my battery took a nose dive had it tested and of course they said it was bad.
funny thing is we had a cold day and this morning i went to work and the truck started fine i don't believe that i left anything on but i noticed my ground cable was loose. cost me 90 dollars and a few moments in the cold with a dead battery.
2000 dodge dakota 4x4 club cab 239000 miles
2004 gtp
2006 hd flhxi
2004 gtp
2006 hd flhxi
the temp got down around 15 here in cleveland ohio today . it was just wild as how it started the truck 8 hours earlier and i went out at 3:30 and it was deader than a door nail. i mean it didn't even click.
after i found someone to give me a jump it wouldn't idle on its own for about 5 minutes, not sure what the deal was there. but it warmed up and it drove it directly to bulldog battery and in a flash plus 90 bucks it was fixed .
even with all that im still only into the truck about $950 . still ahead of the game for a nice 4x4 dakota club cab.
2004 gtp
2006 hd flhxi
2004 gtp
2006 hd flhxi
had to replace mine after just under 3 years.still under warranty,but dodge would only pro-rate the battery,and then i would end up with the same junk.advance auto for $75.00.another good reason for a clutch-a little push and pop start to get home.
Try Interstate - Batteries,.. Man, I've had good luck with those.
I've got them in 3 trucks and 1 car I own.
The one car is a 1st yr Intreped,.. The car is wore the hell out but,
the motor is great in the thing! I bought a re-furbished Interstate,
(Not wanting to put another penny in the thing) because the old batt
went dead on the 1st cold day. 20 bucks-90 day warrenty, can't be beat
for a car that MIGHT last those 90 days anyway!! LOL!!!
I just went through all of that too. Truck went completely dead twice before I got the new battery in, and both times it wouldn't idle on it's own. I think it's because with the complete loss of power the pcm gets reset, and the idle air control motor goes to a default setting until it can "re-learn" what it needs to. With it being so cold out that default setting just doesn't work.
2nd gen trucks do not like to idle with a dead battery. when you go to jump it, cycle the ignition 4 times until a "p done" message shows on the digital vin display, then start her up.
My 1st gen dakota is missing the headlight buzzer so it doesnt remind me when I forget to turn off the lights. Ive walked out of stores and work with a dead battery so many freaking times![:@]
imo, unless ur gna drive on realy steep grades
