4x4 problem help!!!!!!!
Old Jan 6, 2008 | 04:06 AM
kwikquadcab's Avatar
kwikquadcab
Default 4x4 problem help!!!!!!!
i have a 01 dakota quad cab 4x4 4.7 V8. my 4x4 dose not work at all. i thought it was the selector swicth so i replaced it because i had checked all the easy stuff (fuses, loose conn.) but it still dosent work.i have1 wire on the selector switch that has power but i still get nothing. i cant find a wire diagram anywhere on the net, any help will be appriciated please!!!! im going nuts with this problem. the lights on the switch dont come on either.
Old Jan 8, 2008 | 03:16 AM
kwikquadcab
Default RE: 4x4 problem help!!!!!!!
so.... nobody knows about 4x4s or what?!!
Old Jan 8, 2008 | 07:22 PM
f0x672's Avatar
f0x672
if im not mistaken, the 01's were on a recall for the transfer case having operational problems, and wouldnt allow it to shift out of a which ever drive it's in
Old Jan 9, 2008 | 06:18 PM
Nicegy525's Avatar
Nicegy525
could be the shift motor at the t-case
Old Jan 9, 2008 | 07:06 PM
steve05ram360's Avatar
steve05ram360
there is a link to the manual up at the top of the forum. check the shift motor while someone turns the switch... you should see it rotate the shaft going into the t-case. there is a trans case swap DIY writeup that you can use as a reference to locate the shift motor.
Old Jan 10, 2008 | 12:37 AM
kwikquadcab
well i checked power at the shift motor while the ignition was on and i dont have any power at any of the din plug wires, but i do have power at selector switch but only at 1 wire, and when i remove the 4x4 fuse at the fuse box under the hood i still have 12v. went to my locall dodge dealer for a schematic but they "could not print out that information" so they told me that for 90.00 they could check the truck for me[:@]and tell mewhat was wrong with it[sm=bs.gif]any one out there have a wire diagram or something to help me trace the wires
Old Jan 10, 2008 | 08:27 PM
SmokedRail07's Avatar
SmokedRail07
make sure it is not a vacum problem happened to me before
Old Jan 10, 2008 | 11:26 PM
itopete's Avatar
itopete
this was ported by steve05ram360:
is the service manual, has all you need....
http://www.jameskowalski.com/Dodge/2...dge_Dakota.pdf
BTW I got my 2001 4x4 4.7 dakota like 2 days ago and I have the same problem...2h & 2l wont work...so if you find the root of theproblem send me a message please :-D
Old Jan 11, 2008 | 01:44 PM
Radman's Avatar
Radman
kwikquadcab, might check with another repair shop for a print.
I was charged 26 bux for a download of a print for my 02. I had
a electricial problem.
A shop may be able to get what you need...
Old Jan 16, 2008 | 01:53 AM
kwikquadcab
well i finally got tired and took to the dealer, they found that the transfer case module was shorted out its a blue box under the steering colum it cost 240.00 and labor was 3hours@80.00 grand total of 490.00 [sm=chairshot.gif]o-well i took it like a man and they didnt even kiss me after!!! well im off to the sands good luck to all of you all with the same problem and thanks for the help!
