Sealing a Manifold
Old Jan 6, 2008 | 05:16 AM
varsis's Avatar
varsis
Default Sealing a Manifold
Since I bought my truck over a year ago I have this dreaded ticking noise, which I have found to be a manifold leak, or where the manifold connects to the y pipe. I was just wondering what is the best way to fix a leak. The problem is that I don't want to remove them twice, I want it done the first time right. I can't find any gaskets for the v6 mag, 3.9 other than the cheapo graphite gaskets (which plain suck) I was wondering about copper sealant I have read about people using this as it resists upto high temps, and they even have gaskets made from copper but I can't find one for my truck.
Any help would be great!
Old Jan 6, 2008 | 10:01 AM
steve05ram360's Avatar
steve05ram360
Default RE: Sealing a Manifold
you might not need a gasket there depending on the flange type. have you tried unbolting, cleaning the surfaces & then putting it back together? also have you checked for any cracks there?
Old Jan 6, 2008 | 11:35 AM
OneBadKota's Avatar
OneBadKota
Have you tried www.remflex.com ? On the expensive side, but they work.
Old Jan 6, 2008 | 04:43 PM
varsis's Avatar
varsis
I looked at Remflex, but there isn't one for the v6. I did take one side off and put a gasket in, but still no luck. still leaks like crazy, and i didn't see any cracks. looked fine.
Old Jan 10, 2008 | 12:51 AM
varsis's Avatar
varsis
Would my best bet be to take it to a mechanic? Get them to fix it?
Chris
