Caliper Pin
Old Jan 16, 2008 | 05:01 PM
toadhunter's Avatar
toadhunter
Default Caliper Pin
Whats the best fix for stripped knuckle threads?
Old Jan 16, 2008 | 05:04 PM
steve05ram360's Avatar
steve05ram360
Default RE: Caliper Pin
welcome to df...
probably to swap the knuckle out for a used one. you could try heli-coil on it but I'd loose sleep with that in there cause of the brakes... go to the wrecking yard and ask... I bet its pretty cheep.
Old Jan 16, 2008 | 06:14 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
I used helicoil and they worked great and it saves you from spending money on a new knuckle. i haven't had a problem with them since
Old Jan 16, 2008 | 11:41 PM
jonnymagnum's Avatar
jonnymagnum
I helicoiled mine and locktited the hell out of it.
Old Jan 17, 2008 | 12:52 AM
300exoh's Avatar
300exoh
Check out the local auto parts stores. You can usually find an oversized self tapping caliper mounting bolt...I found mine at NAPA but I'm sure others shops carry them. I had to call around to find it though since some places were out of stock. It's a simple fix and only costs around $10.
