tire calculators
Old Jan 17, 2008 | 12:24 PM
scandal669's Avatar
scandal669
Default tire calculators
i found a couple good ones that some may like to use...the secondlink compares truck sizes to metric too. if someone wants to go to a metric size i found that a 265/75-15 is nearly idendical in all size aspects as a 31x10.5x15
http://www.discounttire.com/dtcs/infoTireMath.dos
http://www.1010tires.com/TireSizeCalculator.asp
Old Jan 18, 2008 | 06:21 PM
JCFChamp's Avatar
JCFChamp
Default RE: tire calculators
You should also add that they need to go to a site like:
http://www.miata.net/garage/tirecalc.html
^- To see the effects of going up or down to far in size.
http://www.redrock4x4.com/tech/tire_calc.php
^- Metric to Standard converter or vise versa.
Just figured i'd add my $.02, since when i went up in tire size my speedometer became off by a few mph.
Old Jan 19, 2008 | 01:01 PM
scandal669's Avatar
scandal669
both links show how far the speedo is off when you change tire sizes...in the case of switching from 31x10.5x15 to 265/75-15's the speedo is only 0.6 mph too fast
