cluster lights
Old Jan 26, 2008 | 02:36 PM
gorac's Avatar
gorac
Default cluster lights
I know this has been asked atleast once. I want to change the bulbs in my cluster with some blue LEDs. According to http://www.sylvania.com/ I need to replace them with 158 bulbs, which i ordered WLED-x from http://superbrightleds.com/. Thats suppose to be the direct replacement. When i opened the cluster about an hour ago the bulbs are way to small and without tons of modifications wont. What is the right ones? and where is the best place to get the leds from? I have an 01 Dakota.
Old Jan 26, 2008 | 04:55 PM
w9awx's Avatar
w9awx
Default RE: cluster lights
I know there are several posts dealing with replacing the lights in the clusters but I can't remember what they all said. Time to do a post search.
Old Jan 27, 2008 | 12:59 AM
geoffb123's Avatar
geoffb123
If your looking for replacement lights to go in the cluster, or anything for that matter. Look in the manual. Best place to start for that stuff. Headlight bulb application, dash light bulbs etc. As for the led's being put it. www.vleds.com . Im getting a set for my park lights (front and back) also the reverse lights. Just gotta make sure to get the resistor with them too otherwise you get that annoying fast blinking. They even have bulbs for clusters. Lots to choose from. But im almost positive that the backing of the face on the cluster has got to be changed. Because its just the white bulbs. But the skin is green. Which obviously gives off the green lighting. Not sure how to deal with that though.
