4.7 has rough idle and cuts out
Old Jan 31, 2008 | 07:00 PM
slvr4.7's Avatar
slvr4.7
Default 4.7 has rough idle and cuts out
My 4.7 has rough idle and sometime when I have it in gear backing up or at a light it will cut out. It kinda sounds like its missing, but it seems ok at highway speed. I changed the spark plugs with Autolite copper core and gapped them to .40. Any ideas?
Old Jan 31, 2008 | 07:45 PM
steve05ram360's Avatar
steve05ram360
Default RE: 4.7 has rough idle and cuts out
sounds like the IAC motor is going bad... controls the idle.
Old Jan 31, 2008 | 10:32 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
is there an IAC on the 4.7, i know for the 3.9/5.2/5.9 there is but for some stupid reason i didnt think there was on the 4.7 i could be wrong, but i dont feel like going out to look so you can just correct me if im wrong
Old Feb 1, 2008 | 10:31 AM
CL350RR's Avatar
CL350RR
You may need to clean your throttle body. when they start to build up gunk, the symptom is a rough idle and stalling
Old Feb 2, 2008 | 01:25 AM
slvr4.7's Avatar
slvr4.7
Should have mentioned it has 37k miles and was doing this before I changed the plugs.
Old Feb 2, 2008 | 02:57 PM
imnothot02's Avatar
imnothot02
first off i asume there arnt any codes
could be a bad coil, however that wouldnt cause it to die, im with STEVE on the IAC, while ur at it clean ur whole intake...
Old Feb 2, 2008 | 05:37 PM
slvr4.7's Avatar
slvr4.7
The check engine light hasnt come on at all. I checked the checkers website and it doesnt list idle air anything for this year and engine.
