Is itinadvisable to increase your tire size on thefactory wheels to a larger diameter? I have the 245/70/16s, as there were two tire sizes for this vehicle. I would like to put 305s on, but I'm not sure if this would be safe, or if the new tires would clear the wells.
with 245's on there now, you are at the limit for your rim size...305's wont work on that rim...305's will also rub the fender well. if you want 305's you need new rims and a lift
i would stick with the current ones you have unless you want to upgrade like 1 inch. But best would be to invest in a lift, rims or just larger tires that fit.
