how to make cai?
there are 3 or 4 links thruout this thread for ideas... https://dodgeforum.com/m_1166339/tm.htm
also... http://www.turbomopar.com/craig/dako...dakintake.html
or, you can go to a muffler shop and get them to bend pipe however you want it and get the connectors at home depot.
ill tell you what i did...i cut out the pipe that runs in front of the airbox and into the fender and replaced it with a 3" flex hose straight out front behind the grill next to the radiator, i get cold air straight into the airbox and now feel a good amount of power from about 1500 rpm's and also got about1.5 to 2 more mpg's. i maybe could get more power and milage from a true CAIbut it took me a few minutes to do and cost me less than 10 bucks. one day i might get a good CAI but for now this works great and if you are on a budget like i am, then this will suit you fine.
as far as heat resitant paint? i would, i dont think it gets that hot but id rather be safe than sorry and have to take all apart again and repaint it if it did bubble up from heat
I ran mine through the fender, and down through the bottom of it and mounted the filter right behind the foglight. It has plenty of cold-air, and it's fairly protected from the elements. It's always best to get the filter/inlet OUTSIDE the engine bay.
