Heater Blower
Old Feb 17, 2008 | 06:30 PM
014x4dodge's Avatar
014x4dodge
Default Heater Blower
Hello,
Hope all is well. I started my truck this morning and turn on the blower no blower ok,went to work anyway,going down the road and the blower comes on cool. 2 days later no blower again. What do you guys think? I am seeing alot about the res.pack but not sure this is it because its comes and goes. Before I start buying parts like to know what you guys think it might be.
Thanks for your help
Old Feb 17, 2008 | 07:41 PM
imnothot02's Avatar
imnothot02
Default RE: Heater Blower
sounds like a bad blower to me, however when it comes on can you change the speed?
Old Feb 17, 2008 | 07:55 PM
Sober's Avatar
Sober
does it work on the highest setting? If so, then it is the resistor. If it doesnt work at all, check for power and ground at the blower motor connector, if you have power and ground, you need a blower motor.
Old Feb 18, 2008 | 05:24 AM
014x4dodge's Avatar
014x4dodge
Thanks for your help. No the blower does not come on at all,and if it does come on all the speeds work fine. I will ckeck for power at the connector today.
Thanks again for your help.
Old Feb 18, 2008 | 07:19 AM
Sober's Avatar
Sober
well, if its an intermittent problem and the motor is working then try wiggling the wires that go into it. If there is a break in the wire, that should show it. You could also have a bad switch, hard to tell.
Old Feb 18, 2008 | 12:28 PM
fordogz's Avatar
fordogz
my res. went out4 times .... and the blower did not work at all 3 out of the 4 times ....then the 4th time it was just like yours (but not cold air) and what i found was the wireing plug melted to the res. and could not get them apart... went to dodge dealer and the know about the problem cause the sell the res. and the plug... you have to cut wires and all that crap.... hopes this helps out...
Old Feb 19, 2008 | 01:28 AM
geoffb123's Avatar
geoffb123
Mine went out before. It was an bitch to change. But it blows fine now. But it tightened the screws to hard on one side to the fan on it slaps around inside.
