sounds like i have swamp tires on
Old Feb 17, 2008 | 07:18 PM
DaytonaDakota's Avatar
DaytonaDakota
Default sounds like i have swamp tires on
i drive a 99 dakota R/T i noticed recently, after i changed my fan clutch, when i drive over like 5 miles an hour it sounds like i have swamp tires on my truck, a loud winding or rubbing noise is present. now i have stock r/t rims and tires with, last time i checked only 30 psi. im not sure if its even my tires that are making the noise but its very annoying anyone else have this annoying noise??
also anyone with r/t rims post what you keep you tires at
Old Feb 17, 2008 | 07:44 PM
imnothot02's Avatar
imnothot02
Default RE: sounds like i have swamp tires on
hmmm could be alot of things realy
Old Feb 17, 2008 | 08:02 PM
Sober's Avatar
Sober
The clutch is probably not operating properly. Take the belt off and see if the problem goes away (but dont drive far!!!, it will heat up quick, and suck the battery down). If it goes away, get a mopar clutch.
