Water Leak!!!!
Old Dec 27, 2004 | 09:17 PM
DakMan6704's Avatar
DakMan6704
Default Water Leak!!!!
Ok, so today I went to install my subs under the rear seat and came to a unfourtunate problem. There seems to be a water leak on the passenger side of the cab that runs all the way back to the tool tray. I just noticed it as there have been no mildew smells etc. The dealer will let me know that theyre gonna screw me next tuesday. Has anyone noticed this, or seen any signs of this... I also noticed a small wind noise on the passenger side which could be related, or not. Any ideas/help would well, work. thanks!
Old Dec 28, 2004 | 03:57 PM
moparturd's Avatar
moparturd
Default RE: Water Leak!!!!
Is it a CC Dakota. Maybe the rear window seal.
Old Jan 2, 2005 | 06:24 PM
DakMan6704's Avatar
DakMan6704
it is a club cab, but it appears the majority of the water is coming in the front side of the pillar. i guess ill find out tues....
Old Jan 4, 2005 | 09:17 PM
DakMan6704's Avatar
DakMan6704
Ok...dealer said they found a leak in the 3rd brake lite. The girl said theyve had a few of them...You guys might wanna check yours..just an idea. I need to call tomorrow and make them order me a carpet....
Old Jan 10, 2005 | 05:34 PM
Quadcabber 4x4's Avatar
Quadcabber 4x4
DAKMAN: What kind of subs are you installing? I have a Quad-cab and have been looking for subs to install under back seat(s) and have not had any luck as yet. Fill me in!
Old Jan 10, 2005 | 10:33 PM
DakMan6704's Avatar
DakMan6704
I got an MTX thunderform box...They make one for your truck...but it looks as though it goes behind...which would be acceptable Id think. Its about 130 unloaded, 190 with a pretty cheap MTX sub. I got an unloaded box (no subs included) and put kicker 10" DVCs in there. they took some modifying to get in there..but theyre in...sounds pretty good...got a 1000W amp powering them, might need more power when I find space and get it dry. I can make rings to fit in the box to step the sub out if it needs it for clearance like mine did.
Old Jan 14, 2005 | 08:20 PM
DakMan6704's Avatar
DakMan6704
screwed as planned..."we can only dry it out, then if there is a problem, we can order a new carpet" bastards. Theyll be getting hell from me in a few weeks. any ideas on how to get them to respond with a new carpet in a timely manor?
