Y-pipe solution
Old Mar 16, 2008 | 01:39 AM
TheePlaymaker's Avatar
TheePlaymaker
Default Y-pipe solution
I got to thinking about a way to replace the restrictive y-pipe and i wanted to see what you guys thought. I was thinking run a pipe from each manifold into a 2 in one out hi flow cat. I didn't like the way they put my cat is so i was gonna replace it with this type of set up. Just wondering what your thoughts were on this. Heres a pic of the cat i found.
Old Mar 16, 2008 | 02:57 AM
bpm's Avatar
bpm
Default RE: Y-pipe solution
I'm lookin at doin the same thing...I keep gettin a code for cat. efficiency below threshhold whatever whatever...I was goin to braze a system together,jegs sells universal y-pipes w/ a high flow cat,either way,I think It'll be a project/tough to do yourself,but much cheaper than to havea shop do it. You'll need toadd weld-onO2 sensor bungs,extend the sensor harnesses...etc.,I wouldn't trust any shop around here to do that kind of work the way I'd want it done! The bends of the factory y-pipe just look soooo restrictive!
Old Mar 16, 2008 | 03:01 AM
bpm's Avatar
bpm
where did you find that cat?
Old Mar 16, 2008 | 03:21 AM
varsis's Avatar
varsis
I don't know if that would be much of a better solution,
youd have to have it pretty much below the cab or spend money on a dual system almost, also, you won't be able to the accurate gases present before the cat... If want to fix a y pipe to a x or H pipe, and do a true dual i think that is a dumb idea, those things heat up pretty good so it's best to keep them under the box.
Old Mar 16, 2008 | 06:28 AM
HankL's Avatar
HankL
that is the factory design
of the 1993-1995
"light duty" Z in VIN number
Magnum 5.9 V8s catalytic converter in Rams
they changed the catalytic con design in later model years
the heavy duty Magnum 5.9V8s
had dual catalytic converters
and less back pressure
and made max torque at 2800 rpm
rather than at 3200 rpm like the light duty 5.9V8
Old Mar 16, 2008 | 05:39 PM
BLACK98RT's Avatar
BLACK98RT
Why not just have a lrger Y pipe made of 2.5" from a shop with a better merge area, and just keep a 3" high flow cat. That should not cost much, and that 2 into 1 cat is probably prety expensive.
Old Mar 16, 2008 | 08:43 PM
TheePlaymaker
after looking at how its set up today i see what you guys are saying ill probably just get a better y-pipe and weld that in. i thought it was set up different for some reason must have been thinking of some other type of vehicle.
