quick electrical question
Old Mar 18, 2008 | 02:57 PM
yellowjacket99's Avatar
yellowjacket99
Default quick electrical question
To bring you up to speed, my driver side tail light went out. The power wire for it broke inside the wire loom under the bed. Fixed that last weekend. I tested the tail light, worked; tested the blinker, worked; brake light, worked. Today I found that with the tail lights on, the blinker won't work, but it will if the tails are off. It might flash once, but then the light in the cluster just stays on and neither the front or rear blinker work. Is this a ground issue, or a short, or something else?
Thanks.
Old Mar 18, 2008 | 08:41 PM
moe7404's Avatar
moe7404
Default RE: quick electrical question
moe in wichita ks
in the past ALL wiring going to rear of the truck or car passed through the turn signel switch first under the steering wheel. and if you had a car with lots or miles the first thing you would check was the turn switch. no charge for this one, HA HA HA
Old Mar 18, 2008 | 09:28 PM
imnothot02's Avatar
imnothot02
ever change the buld and lube the bulb holder i use vaseleene sp? sure that contact lube is better but either works..
Old Mar 18, 2008 | 10:18 PM
ricbrk's Avatar
ricbrk
KInda sounds like a ground or crossed wires.
Old Mar 19, 2008 | 04:22 PM
lone_wolfin's Avatar
lone_wolfin
i agree with ricbrk..............sounds like a bad ground...
1 thing can workwith the bad ground, but the 2nd wont
Old Mar 20, 2008 | 01:58 PM
yellowjacket99
Alright. Hopefully I'll get some time this weekend to check it out. Driving my car until then.
