DOT question
Old Mar 20, 2008 | 01:15 AM
crateampsrock's Avatar
crateampsrock
Default DOT question
Ive recently purchased a set of aftermarket marker lights which replace the OEM amber to the clear lens to make a clear on clear headlight assembly. I am not familiar with Texas DOT regulations, would it be mandatory that i change out the original clear bulbs to amber bulbs?
Old Mar 20, 2008 | 01:16 AM
crateampsrock
Default RE: DOT question
I will fix my sig later...
Old Mar 20, 2008 | 02:01 AM
geoffb123's Avatar
geoffb123
I have a different headlight assembly than yours. I have the halo projector assembly, it it clear also. I did switch out the clear bulbs to amber. I wouldn't want to take a chance with it. Some cop sees that and you could get a ticket. Plus a package of 2 3157 amber bulbs is only 5$. I would. Plus it only takes about 10min.
Old Mar 20, 2008 | 08:12 AM
ricbrk's Avatar
ricbrk
Texas law states that you have to use White or Amber to the front. I'd get Amber bulbs, but I don't think you have to ?
References:
[ul][*]Texas Transportation Code
§ 547.321. Headlamps Required
§ 547.3215. Use of Federal Standard
§ 547.322. Taillamps Required
§ 547.323. Stoplamps Required
§ 547.324. Turn Signal Lamps Required
§ 547.325. Reflectors Required
[*]49 CFR Section 571.108[*]NHTSA - Safety Standards[/ul]
[align=left]For clear taillight lenses to be legal, they must consist of the following components. [/align][align=left][align=left]Stop Lamp
All motor vehicles are required to have at least two (2) stop lamps, unless vehicle was manufactured prior to 1960, in which case it is required to be equipped with one (1).
A stop lamp must emit a red or amber light, or any shade of color between red and amber.
A stop lamp must be visible from a distance of not less than 300 feet to the rear in normal sunlight.
The stop lamp shall be actuated upon application of the service (foot) brake and may be incorporated with one or more other rear lamps.
Stop lamp lens must be of a type meeting Department of Public Safety standards.
[/align][/align]Tail Lamp
Every motor vehicle shall be equipped with at least two taillamps, unless vehicle was manufactured prior to 1960, in which case your vehicle is required to be equipped with one (1) taillamp mounted on the rear which, when illuminated, shall emit a red light plainly visible from a distance of 1,000 feet to the rear.
Rear Reflector
Every motor vehicle shall carry on the rear, either as part of the tail lamps or separately, two or more red reflectors.
Rear reflectors on a vehicle shall reflect a red color.
Red reflectors required on the rear of a vehicle may be incorporated with the tail lamp assembly.
Every reflector upon any vehicle shall be of such size and characteristics and so mounted as to be visible at night from all distances within 600 feet to 100 feet from such vehicle when directly in front of the the lawful lower beams of head lamps.
Turn Signal
Signal shows white or amber to the front, and
Signal shows red or amber to the rear
Old Mar 20, 2008 | 09:16 PM
crateampsrock
ricbrk thanks for the resource, indeed it states that under texas law, section 547.324 under the transportation code,
(c) Turn signal lamps:
(1) shall be mounted at the same level and spaced as
widely apart as practicable on the front and on the rear of the
vehicle; and
(2) may be included as a part of another lamp on the
vehicle.
(d) A turn signal lamp shall emit:
(1) a white or amber light, or a color between white
and amber, if the lamp is mounted on the front of the vehicle;
Old Mar 21, 2008 | 10:52 PM
RoaminGnome's Avatar
RoaminGnome
In NH you MUST have amber. I knew someone who had clear bulbs in his after market headlights and tail lights, and other than getting harrased by cops they where like spotlights! Im suprised he didnt cause any accidents, damn ricers.
