1997 Dodge Dakota SPEEDO NOT WORKING HELP!
Old Mar 24, 2008 | 05:59 PM
thunderace31's Avatar
thunderace31
Default 1997 Dodge Dakota SPEEDO NOT WORKING HELP!
Ok we got my Girl a very nice 97 Dakota Manual trans. V6 Runs great! But on her way home from work today the Speedo stopped working and threw a check eng. light.
I thought No big deal just a cable BUT! I cant find a cable!???? Confused????
Is there a cable and if so where can we get a new one. Or what else could be wrong??? Speed sensor???
HELP!!!!!!!!!!!!!!
Thanks
Old Mar 24, 2008 | 07:20 PM
varsis's Avatar
varsis
Default RE: 1997 Dodge Dakota SPEEDO NOT WORKING HELP!
ORIGINAL: thunderace31
HELP!!!!!!!!!!!!!!
Thanks
Probably a ground cable or the dash isn't set properly.
Old Mar 24, 2008 | 08:14 PM
imnothot02's Avatar
imnothot02
ur speed sensor is shot, not sure where it is on the manual tho, may be over the rear axle? or on the tranny, buy a Haynes bible
Old Mar 24, 2008 | 08:19 PM
thunderace31
Thanks!
Just needed to confirm before I go buy more crap for it lol. Truck needed a brake light switch 1st day we had it
Old Mar 24, 2008 | 08:34 PM
imnothot02's Avatar
imnothot02
ha my bad pull the codes first, didnt read the whole post
P0500 Vehicle Speed Sensor (VSS) Circuit
P0501 Vehicle Speed Sensor Range/Performance
P0502 Vehicle Speed Sensor (VSS) Circuit Low Input
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent
Old Mar 24, 2008 | 08:56 PM
thunderace31
Can you get the codes off this truck like other Dodge and Chry. products?? Just turn the key 5 times and count the flashs on the check eng. light???
Thanks for the help guys!
Old Mar 24, 2008 | 10:26 PM
imnothot02's Avatar
imnothot02
no you need a obdII you have a autozone around there? buy one they are only like 30-40 for the one you will need... they ahve nicer ones but save the cash..
Old Mar 25, 2008 | 03:10 AM
BLACK98RT's Avatar
BLACK98RT
You should not even need to buy one, if there is any large chain autoparts store near you they will usualy run your codes for free in an effort to sell you the part to fix it.
Old Mar 25, 2008 | 11:54 AM
thunderace31
Problem is the truck stopped running this am so something more than a speed sensor has to be wrong
Ihope this thing dosnt turn out to be a P.I.A
Old Feb 14, 2012 | 11:06 PM
Devon Stringer's Avatar
Devon Stringer
Default speedo not working
hey there i have been looking for some help i have a 1999 3.9 dakota 4x4 i just changed the alternator and since then everything BUT the speedometer work the wired shorted for a second while i was doing it (stupid me for forgeting to disengage the battery) anyway could i have caused damge to the computer or do you think i could have fried a sensor or a wire possibly?
