2000 Quad 4x4 wont start
Old Apr 6, 2008 | 10:41 AM
ArthurJHeilman's Avatar
ArthurJHeilman
Default 2000 Quad 4x4 wont start
I have a 2000 4.7 and i had a cam position sensor code and changed that , also checked the voltage on that and the crank sensor and both are good. But it still wont start, it coughs back through the intake when cranking ANY HELP would be great !!!!
Old Apr 6, 2008 | 06:10 PM
moe7404's Avatar
moe7404
Default RE: 2000 Quad 4x4 wont start
moe in wichita ks
most of the time a backfire means its too lean, however even rarer is backfire when its too rich. but first check the rotor and cap, iLL bet its wet. if you put a new cap on, block off the vent in the cap, this keeps wettness out. j b weld works good for this. i have been doing this for years seams to work. for years i put a new cap and rotor on each fall, cheep insureance.
Old Apr 6, 2008 | 06:13 PM
ArthurJHeilman
on a 4.7 there is no cap and rotor .....
Old Apr 6, 2008 | 08:02 PM
varsis's Avatar
varsis
o2 sensor or bad gas... From the sounds of it.
Old Apr 6, 2008 | 10:18 PM
moe7404's Avatar
moe7404
moe in wichita ks
i guess iam stuck in the past. just last fri i got draged kicking and screeming in to the 20 th century, i got my first cell phone.
Old Apr 6, 2008 | 11:49 PM
varsis's Avatar
varsis
ORIGINAL: moe7404
moe in wichita ks
LOL, yes. 4.7 is way different.
Old Apr 7, 2008 | 04:04 PM
ArthurJHeilman
Ok if its the o2 sensor why the dont i get a code for that ? No codes at all
