another engine swap question
Old Apr 8, 2008 | 11:20 PM
Blackdak97's Avatar
Blackdak97
Default another engine swap question
my 4 banger has seen better days. its only got 115000 miles but it ticks like a clock. im am going do the V8 swap. so here are the questions......
engine:
318 or 360?...obviously the 360 but i want a 5 speed. what do i do as far as a fly wheel?
trans:
i love driving 5 speed so that is what i want. will the 3.9 5 speed trans hold up?
rear end:
i called the local junk yard and they told me that my rear end will work i just need to change the gears
computer:
if i go with the 318 i can find a 5 speed computer. if i go with the 360 will i have to get a custom burnt computer becuase 360 did not come with a 5 speed computer, and where can i get this done?
i probly forgot something so if i need do do anything else to make this swap posible let me know. thanks
Old Apr 19, 2008 | 10:59 PM
01dakota440's Avatar
01dakota440
Default RE: another engine swap question
ever thought about the computer from a ram that had a 5 speed. and you could use the whole tranny and fly wheel
Old Apr 20, 2008 | 04:09 AM
varsis's Avatar
varsis
ORIGINAL: Blackdak97
engine:
trans:
rear end:
computer:
360 is better, but externally Balanced.
Just make sure it has the weights on the flywheel/Flex Plate.
It is possible just a bit harder to do. The mounts are line up.
Old Apr 20, 2008 | 08:36 AM
JasonA's Avatar
JasonA
I don't see why you'd need to change gears. The2.5L enginewould probably have come with some of the shorter gear ratios (like 3.55 or 3.92). These would be great for a 5.9L engine.
Old Apr 20, 2008 | 11:22 AM
scandal669's Avatar
scandal669
sounds like an aweful lot of work to me. i dont know for a fact but when its all said and done it might be worth just getting a new truck. its going to cost more than the truck is worth to do all those changes...or id just replace the 4cyl and maybe do a few mods to it.
Old Apr 20, 2008 | 12:12 PM
imnothot02's Avatar
imnothot02
exactly ^^^
