2001 Dakota
Old Apr 13, 2008 | 03:04 AM
ID_Neon's Avatar
ID_Neon
Default 2001 Dakota
My instrumentcluster fails to read-out any readings, fuel, odometer, speedometer, etc.
The panel lights up, no indicator lights come on, turn signal lights come on.
From what I understand it can be a fuse problem (elaborate please), a PCM problem feeding information to the cluster (elaborate please) a CCD connection to the cluster (elaborate please) or a failure of the cluster itself.
If it's a fuse, PCM, or CCD problem, what are the fixes, generally, and what fuse am I looking for particularly?
Thanks.
Old Apr 13, 2008 | 01:51 PM
varsis's Avatar
varsis
Default RE: 2001 Dakota
Check the ground cables, one can cause that.
Old Apr 13, 2008 | 02:25 PM
ID_Neon's Avatar
ID_Neon
What would I be looking for in that case? Just a ground that's loose or disconnected or such?
Old Apr 14, 2008 | 10:36 PM
00DakR/T's Avatar
00DakR/T
Do you also have a "no bus" message in the odometer?
