ifs diff question
Old Apr 14, 2008 | 06:50 PM
bbcrack's Avatar
bbcrack
Default ifs diff question
just wonderin if the 02and newer ram and the dak share the same ifs diff. im concidering a gear swap(3.55 now) and know u could get a ram or a dak with 3.92 gears which are what im concidering. been lookin around in the local junkyards... just wonderin if i could ****** the whole ifs assembly and bolt it up, or if i would be better off just grabing the ring and pinion...also would i need to get the carrier? idk if my 3.55 carrier will work with the 3.92s. i hav the 9.25 rear and i kno parts will swap from a ram, just looking mainly 4 info on the ifs. oh yea is 3.92 the lowest gear avaliable in a dak or a 1500 ram? im trying 2do this swap on the cheap. any info will help me out alot. thanks
Old Apr 15, 2008 | 04:30 PM
bbcrack's Avatar
bbcrack
Default RE: ifs diff question
no1 on this site knos anything that can help me? any lil piece of info can help me out
Old Apr 23, 2008 | 10:38 PM
demolition man's Avatar
demolition man
Not sure if diffs. are the same on ram. Dealer or Yard should be able to tell you.
Thats big bucks for that swap, 2 axles.
Pretty sure 3.92 is lowest gears avail. If u change the gears only, u have to shim for pinion depth and backlash. Guess u need the gears for the 33's.
