rear end hook up
Old Apr 15, 2008 | 11:10 AM
Loud Pedal's Avatar
Loud Pedal
The Total Package
Default rear end hook up
im tired of my truck doin a one wheel squeal!!!! i know theres no way to get around it during a turn but from a dead stop i cant get it to hook up...im pushin 20" rims but even with the old ones i still couldnt...my friends 98 sonoma ZQ8 5 speed can spin both wheels goin around a turn, on a roll start, and at a dead stop. what can i do to get the truck to hook up without changingthe rear end gear unless its real cheap
Old Apr 15, 2008 | 12:29 PM
spencea15's Avatar
spencea15
Default RE: rear end hook up
You need a locker or a limited slip.
I can spin both of Mine, i have a limited slip, not cheap to do.
Old Apr 15, 2008 | 01:00 PM
KillClutch's Avatar
KillClutch
What you need to get is a limited slip locker rear, i have one in my dakota its made by powertacx one of the best out there. It is all machanical an uses NO clutch plates, heres a web site for were i got mine from. This unit will allow both tires to spin under acceleration but if you make a turn it will alow each tire to turn at its own speed, but if you hit the gas you will dedinitly spin both an whip it. http://www.drivetrain.com/noslipdodgetruck.html#Dakota..... this is a link to the web site it also describes how it works. This part its awsome, it is like havein a possi rear but you can still make your turns with out problems, unless your feelin you want to whip it.
Old Apr 16, 2008 | 02:03 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
i was thinking of along the lines of under $$$200
Old Apr 16, 2008 | 07:46 PM
imnothot02's Avatar
imnothot02
the junk one that comes stock is ur only option, but if ur gna mash on it alot ull sheel that in 6months..
www.car-part.com
