o2 simulator where to buy?
Old Apr 17, 2008 | 06:23 PM
varsis's Avatar
varsis
Default o2 simulator where to buy?
Were can I buy 2 of these, My truck only has 2 but my 5.9 harness has 4 sensors spots. So I guess that Is my only hope really...
Old Apr 17, 2008 | 07:19 PM
batman13's Avatar
batman13
Default RE: o2 simulator where to buy?
http://www.thefastman.com/02Simms.asp
Old Apr 17, 2008 | 11:52 PM
00DakR/T's Avatar
00DakR/T
As a side note to the o2 sim thing, the guy I bought my truck from had a pretty cool idea. Of course, when you remove the cat, and leave the o2 sensor plugged in, the MIL light comes on. It does this because the PCM sees no change in the signal between the front and rear o2 sensor and with a cat in place, it should. So he removed the cat, put pipe in place of it, and zip-tied the rear o2 sensor to the frame. This way, the sensor still sends a signal and the signal is different enough from the front o2 sensor to keep the MIL light off. Pretty cool.....you should try it
Old Apr 18, 2008 | 03:09 PM
batman13's Avatar
batman13
just orderd my o2 simm from the fastman
will let you know how it goes, mine currently runs real lean
Old Nov 26, 2010 | 02:35 PM
daleas88's Avatar
daleas88
Did that simulator work for your truck?
Old Nov 28, 2010 | 08:24 PM
bugmenot's Avatar
bugmenot
Wow. You got ripped off. You shoulda just bought a 2 pack of spark plug defoulers. They run like a buck fifty.
All you do is drill one out with a 1/2" drill bit most of the way through, so the sensor fits in it. Then with the sensor screwed into one defouler, plug the other defouler into the end of that, and screw that whole thing back into the o2 bung.
Works 100% of the time. No light. No huge waste of money. Easy, and takes about 10 minutes with no modification to your wiring or anything else.
Old Nov 30, 2010 | 01:50 PM
Loud Pedal's Avatar
Loud Pedal
The Total Package
This all happened 2 years ago......
Check your thread dates people
