5.9L half runs
Old Apr 20, 2008 | 12:03 PM
  #31
varsis's Avatar
varsis
Default RE: 5.9L half runs
ORIGINAL: wink2873
i cant see the video, i extracted the file but nothing will play it.
Quicktime.
The guy who pulled the engine told me it ran good when he removed it but had to shut it off quickly because the oil filter had a hole in it and started leaking every where. I did seen the oil though.
I am going to go buy some wires today see what happens, and some seafoam.
No blue smoke, nothing just white, and idles really really rough. I did put it at 1, and it seemed to be pointing at 1.
Old Apr 20, 2008 | 12:11 PM
  #32
imnothot02's Avatar
imnothot02
that there is a bad motor, back to what i told ya a long time ago, why wouldnt you tear the thing down before you put it in, tell you rite now that thing has bad rings and everything else, ur wasting ur time in other words...
Old Apr 20, 2008 | 12:12 PM
  #33
varsis's Avatar
varsis
ORIGINAL: imnothot02
I was afraid of that...
Guess the engine is going back to where it came from... lol.
Old Apr 20, 2008 | 12:39 PM
  #34
varsis's Avatar
varsis
Just to let you know in the vid the constant clanking is beer bottles I have in the back... Forgot to mention that...
Old Apr 20, 2008 | 12:45 PM
  #35
imnothot02's Avatar
imnothot02
from that video, that motor sont sound good at all, dependin on what is wrong it may be a easy fix, hard to tell from a video for sure tho...
Old Apr 20, 2008 | 12:51 PM
  #36
varsis's Avatar
varsis
Il, try and get a better one that was with a cell...
Old Apr 20, 2008 | 01:08 PM
  #37
varsis's Avatar
varsis
I don't think it's the motor it has to do with timing Look at this:
http://www.varsisstudio.com/2.3g2.zip
Looks like gas behind the exhaust...
Old Apr 20, 2008 | 01:20 PM
  #38
JasonA's Avatar
JasonA
For that much fuel, your spark plugs have got to be soaked when you pull 'em, yes? You're sure it's fuel, and not oil or coolant (it doesn't look like oil)? What is your fuel pressure with the key on and system primed? Should be close to 50 PSI.
Old Apr 20, 2008 | 01:23 PM
  #39
varsis's Avatar
varsis
ORIGINAL: JasonA
I don't have anything to check the fuel pressure with, im pretty sure it's gas, because my coolant is green, and the oil is brownish... Not sure what is causing that much gas though, that was all just than, and yes we do have snow what a bummer... How do you check the PSI pressure? I am thinking there is a problem with spark or gas timing.
Old Apr 20, 2008 | 04:12 PM
  #40
wink2873's Avatar
wink2873
well she's blowing gas out the exhaust that means it's not firing, Check your coil, make sure its not weak. The timing chain could be loose. If all else fails, have the truck towed to a mechanic or something. I dont think there's anything major wrong with the engine or it wouldnt even turn over.
