TB bolts
Old Apr 18, 2008 | 09:04 PM
rpowell's Avatar
rpowell
Default TB bolts
Anybody know the torque specs? Think my TB might be suckin a little air.
Old Apr 18, 2008 | 09:44 PM
imnothot02's Avatar
imnothot02
Default RE: TB bolts
change the gasket, and spec oh 19lbs
Old Apr 19, 2008 | 07:31 AM
JasonA's Avatar
JasonA
What is the symptom?
Old Apr 22, 2008 | 06:05 PM
rpowell's Avatar
rpowell
Bolts seem to be tight, I haven't sprayed around it while running yet. It sometimes stumbles while idleing and kinda stumbles when I first give it gas, but cleans up once I give a little more gas. It only acts like this every once in awhile. It does seem to do it more when its cold or right after a fill up. I have checked all the vaccum lines and I am not getting any codes. Checked the TPS and it is within specs for voltage, but don't know if maybe it is going out and only seems to act up at certain times. Any ideas on what to check and how to check it?
Old Apr 23, 2008 | 12:00 AM
TheePlaymaker's Avatar
TheePlaymaker
hmm i didnt check for torque when i did mine lol just tightened them down anyways i'd try to see if its leaking then if not its most likely the tps.
Old Apr 23, 2008 | 06:18 PM
Boulee's Avatar
Boulee
the dak i just picked up i believe is doing the same thing. While idleing either in drive or nutral, the engine runs a little rough. like maybe the idle is set to low maybe.
Have you found the source/fix for yours yet?
Old Apr 27, 2008 | 10:10 PM
tspeed109's Avatar
tspeed109
It sounds like you need to clean the air intake sensor that is located in the hose going to the airbox. Replace the pvc valve too and give that a try.
Hope I have helped. I have done this to my 4.7 and changed the plugs to autolite and it helped out alot.
