tranny fluid level
Old Apr 21, 2008 | 03:40 AM
sgratto96's Avatar
sgratto96
Default tranny fluid level
i have a 45rfe auto tranny in my dakota and when i serviced it in december (filters, gasket, full synthetic fluid) i put in 6 quarts of oil. when i check the dipstick level properly with the truck hot in neutral, level and running it says my fluid is on the low mark. there are no leaks whatsoever that i know of. is this because i am checking it wrong? i know this tranny should only take 5 1/2 at the most quarts but it hasnt had any problems with 6. i know tranny fluid is very thin so maybe im just not seeing the dot correctly.....thanks
Old Apr 21, 2008 | 11:24 PM
imnothot02's Avatar
imnothot02
Default RE: tranny fluid level
sure its the correct dipstick?, proaly low, the 5 quarts is a refrence, youmusta had a lot of "flowback" you just dropped the pan rite?
Old Apr 22, 2008 | 01:23 AM
sgratto96's Avatar
sgratto96
ya i dropped the pan awhile back and it was fine but i mean in the end i put in 6 quarts so im not gonna worry about it. and im sure i could have gotten away with 5 1/2
Old Apr 22, 2008 | 01:32 AM
varsis's Avatar
varsis
The fluid level probably references to the level that is within the pan, but if you probably know, more could have come out, from the valve body, externals ect... so I can see this, just add it in. Unless you see it in your radiator with your coolant than you are good.
