2003 dakota air bag light on
Old Apr 25, 2008 | 10:16 PM
cfd45's Avatar
cfd45
Default 2003 dakota air bag light on
Can anyone tell me why my airbag light is on? And how do I fix this? Thanks
Old Apr 26, 2008 | 12:51 PM
kchopper's Avatar
kchopper
Default RE: 2003 dakota air bag light on
Your going to have to find out what code you have. Does your horn or cruise work? If not, more than likely your clockspring is at fault. I work on these for a living and more often then not it's the clockspring. Once in a while the airbag module goes bad. Hope this helped.
Old Apr 29, 2008 | 12:22 PM
lone_wolfin's Avatar
lone_wolfin
how do you get codes for the air bag system?
Old Apr 29, 2008 | 09:11 PM
00DakR/T's Avatar
00DakR/T
You would have to take it to a dealership or a repair shop with the right scanner to read airbag codes. But its a pretty good assumption that if you have a highline dakota, and your steering wheel radio controls, horn, cruise or any of the above don't work, you have a bad clockspring.
Old May 17, 2008 | 01:14 PM
03sxt3.9's Avatar
03sxt3.9
where is the clockspring, in the column where the gear shift is or wut, cuz i think mine broke when i put a body lift on, how can you tell if its broke
Old May 20, 2008 | 11:32 PM
00DakR/T's Avatar
00DakR/T
The clockspring is directly behind the steering wheel. Its usually not possible to tell if its broken, but if your horn and cruise don't work, its a good possibility thats its the problem.
Old May 21, 2008 | 04:20 AM
TheDrumThumper's Avatar
TheDrumThumper
I'm having similar issues with my 2002 Dakota. In addition to the Airbag light, the ABS and Parking Brake lights are staying on as well, along with the speedometer not working. This has happened two nights in a row, but everything worked ok during the day. Is this a clockspring issue as well?
Old May 21, 2008 | 09:34 AM
00DakR/T's Avatar
00DakR/T
That sounds more like some sort of a bus issue but without any codes its hard to tell
