Overfilled tranny... can i just syphon it out?
Old May 1, 2008 | 09:36 PM
syllinx's Avatar
syllinx
Default Overfilled tranny... can i just syphon it out?
Not sure if i spelled it right lol but I just changed filter and noticed i was dumb enough to put to much fluid. I don't want to pull pan again so I was wondering if I could use a gas syphoner to pump out the extra fluid?
Old May 1, 2008 | 09:43 PM
00DakR/T's Avatar
00DakR/T
Default RE: Overfilled tranny... can i just syphon it out?
Yeah you can. I dunno how well one of those gas syphons would work, but I use something like that to suck the fluid out before I do my trans services. Makes the whole thing alot less messy
Old May 1, 2008 | 09:58 PM
syllinx's Avatar
syllinx
Yea i hope this will work i noticed before the filter change it was overfilled... filter wasn't bad but now im hoping the shifting issue when it was cold is over when the fluid lvl is right.
Old May 1, 2008 | 10:06 PM
padodgeram's Avatar
padodgeram
Rember: having a overfilled trans , is just as bad as not having enough , do what you gotta do to take care of it ASAP.. syphon should do the trick..good luck !!
Old May 1, 2008 | 10:19 PM
syllinx's Avatar
syllinx
Thanks for the help will buy the syphon kit tomorrow.
moe7404's Avatar
moe7404
moe in wichita ks
go to wall-mart go to the automotive section. get a fulid pump, not the one thats a bulb in a hose. get the one thats a cyl.the one i had was hard to get it working, but keep working on it. use it to pump out the fulid, but pump out an extra two qts. then add back two qts of rear end grease, it will shift better and last longer. change fulid every 30,000 miles
Old May 1, 2008 | 11:01 PM
imnothot02's Avatar
imnothot02
save the money, get a clear piece of hose suck on it just done drink it!
Old May 1, 2008 | 11:05 PM
syllinx's Avatar
syllinx
Do you remember how much the one at walmart was?
Old May 2, 2008 | 10:03 PM
dhvaughan's Avatar
dhvaughan
you could also remove a cooler line, crank the truck and let some pump out.
Old May 3, 2008 | 02:09 AM
varsis's Avatar
varsis
ORIGINAL: dhvaughan
Yea, you can run the tranny almost dry like this. Thats how you do a flush... Just hook a hose up, and run some out, put the park brake on and in neutral. Runs the tranny.
