more lift
Old May 7, 2008 | 10:32 AM
erice's Avatar
erice
Default more lift
I was thinking of lifting the truck up more, and I was thinking is there a system for the Dakota same as if you wanted to lift the front on a ford were you would place a spring spacer adding space from the spring to the body. I already did the torsion bars to get the 2” so if they make a spacer out there for a 03 That way I can do 4” blocks in the back 2” torsion and 2” spacers with the 3” body would give 7” of lift total allowing for 35" tires
thanks
