Squeek when releasing brakes
Old May 7, 2008 | 11:48 AM
greenweenie's Avatar
greenweenie
Default Squeek when releasing brakes
I get this wierd squeek occasionally when I let off the brakes from a stand still. I know this is a shot in the dark, but if this is a common problem maybe someone knows what it may be?
Sounds like maybe it's coming from the rear, do these trucks have problems with leaf spring bushings maybe? The rear axle would be loaded up with the tranny in drive and the brakes on sitting at a stop light...
Thanks everyone.
Old May 7, 2008 | 12:06 PM
300exoh's Avatar
300exoh
Default RE: Squeek when releasing brakes
If I had to guess I would think it might be your rear brake shoes realeasing. Many times rear brakes get replaced but people get in a hurry and don't lube the contact points where the shoes touch the backing plate. Could also be bushings in the rear leaf springs, sway bar or even the shocks. My best guess is that it is in the rear brakes though.
Old May 7, 2008 | 07:48 PM
00DakR/T's Avatar
00DakR/T
I would have to agree with 300. Its probably your rear brakes. Try this though.....get a couple of cans of good brake clean. Take your wheels and brake drums off and spray all the springs and contact points really good....try to get as much of the brake dust off as you can including any inside the drum....and put it all back together. This should take care of it
Old May 7, 2008 | 08:21 PM
greenweenie
Thanks guys!
